Reymartinez28
Apr 11, 2023Aspirant
mr60 and 2 satellites slow wifi
so my system updates to the current firmware and wires my speeds are as expected i use a cax80 as a modem " Wi-Fi is disabled so no signal interference" and I use my mr60 with 2 ms60 sats in a 2500 ...
Apr 12, 2023Guru - Experienced User
For the size of home, you really only need the CAX80 or use the CAX80 in modem mode and use the MR and just 1 MS satellite.
30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
Though as suggested, you can use the CAX80 as its more capable than the MK system is. Even in my 5000sq ft home, my CAX80 covers all areas by itself.
Reymartinez28 wrote:
so my system updates to the current firmware and wires my speeds are as expected i use a cax80 as a modem " Wi-Fi is disabled so no signal interference" and I use my mr60 with 2 ms60 sats in a 2500 sq-ft home i have it backchanneled for connection between the MR and 2 MS wired I get 940 down and 105 up i use cox internet services but i run tests on my Wi-Fi set up and I'm capping at about 350 to 400 down up is about 95 I've factory reset it 3 times today and downgraded a few firmware's before i just gave up and did one last final factory reset and used the current firmware for the MR and MS I'm at a loss someone please help !
