Reymartinez28
Apr 11, 2023Aspirant
mr60 and 2 satellites slow wifi
so my system updates to the current firmware and wires my speeds are as expected i use a cax80 as a modem " Wi-Fi is disabled so no signal interference" and I use my mr60 with 2 ms60 sats in a 2500 ...
Apr 12, 2023Guru - Experienced User
The CAX80 is quite a bit more capable than the MR60 in terms of wireless speeds.
Its a 4x4 antenna with 4800mbps possible on the 5ghz.
The mk system is only 1200mbps over the 5ghz.
Plus the MK system doesn't have a dedicated backhaul like the tribands as its only a dual band.
So its satellites will have lower speeds than the MR router.
Quite a performance difference.
You'd be better to leave the CAX's wifi enabled and put the MK60 kit in access point mode.
Just make sure the MK system is on different wireless channels and uses a different ssid.
Then you can use the speed of the CAX80 for the closer devices while using the MK system for those at the peripheral.
You might even notice the CAX having better speeds than the satellites at the size of your home. IF the CAX is centrally located, it should cover the whole home.
Reymartinez28
Apr 12, 2023Aspirant
i agree the cax80 gave me better speeds but fell off as it has to be located upstairs in front room of house and the house is heavily shielded as i live near Luke afb in AZ. So i can use my cax80 and put the mr60 and 2 ms60 sats in access point mode ? would I just leave the wireless channels on auto so they don't overlap? would this set up act like a mesh still or would I still have to manually connect to the closest router/AP for example one side of the house to another with my iPad or will it do it automatically for me like the mesh system. Sorry for all the questions lol I've never had an issue with the Wi-Fi speeds until now
- FURRYe38Apr 12, 2023Guru - Experienced User
I would disable the wifi radios on the CAX while you test the MK system in AP mode.
30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
For MESH systems, it's up to the connecting device to pick and choose where they connect too.
- Reymartinez28Apr 12, 2023Aspirant
the cax 80 is currently disabled i will try that also
- michaelkenwardApr 12, 2023Guru - Experienced User
Which bit? Wifi? Router? All of it?
The devil is in the detail.
