Kaherdin
Nov 28, 2021Guide
MR60 Backup settings don't backup
Netgear. Are you TRYING to f up?! I've backed up all my reserved up addresses. And what happens after a full reset, and I've restored my backup file? Nothing! The backup backed up exactly NOTHING. ...
Nov 28, 2021Guru - Experienced User
What browser are you using?
Does MS Edge, IE11 or Firefox do same thing?
Kaherdin
Nov 29, 2021Guide
On the MR60 im using the latest firmware, as of Netgear product page for MK60/MR6x.
I'm not enclined to try to do a backup, reset the MR60, and try a restore just to prove a point.
My point is that the software pushed out by Netgear is lacking to the degree that they need to face the music and enable flashing of open scource software for the users IF the user wants to.
Stop trying to stop me from utilizing the hardware, when in this case the software is lacking!!
- FURRYe38Nov 29, 2021Guru - Experienced User
Then you'll need to contact NG support and let them know what your having problems with then.
Good Luck.
