bberenberg
May 03, 2020Aspirant
MR60 can't detect ethernet cable
I just bought an MR60 mesh system with two satellites. I am connecting to Comcast Xfinity via a Surfboard SB6121 modem. The router will not recognize the Ethernet cable that runs between the router a...
Christian_R
May 06, 2020NETGEAR Employee Retired
Hi bberenberg,
May you try setting up the router using a web browser and visiting routerlogin.com.
Christian
bberenberg
May 06, 2020Aspirant
Thank you for the suggestion, but unfortunately that is one of the first things I tried.
Barry
- Christian_RMay 07, 2020NETGEAR Employee Retired
Hi Barry,
I would suggest a factory reset on the MR60 by holding down on the reset button for 15+ seconds. I would also check to ensure the ethernet cable is plugged into the correct port. It's fairly odd how the issue is occurring on both routers.
Christian
- bberenbergMay 07, 2020Aspirant
Thanks, I tried both when I was on the phone with tech support.
- Christian_RMay 08, 2020NETGEAR Employee Retired
Hi bberenberg,
May you send me a private message with your email address and case number(s). I'd like for support to follow up on your case and have it escalated.
Thanks,
Christian
