Idk2022
Oct 27, 2022Follower
MR60 Compatibility
I have the MR60 Whole home system. That model appears to be outdated. What satellites will work with it now?
Oct 28, 2022Guru - Experienced User
Its not outdated. Its just not the highest performing. You can use the MS60 satellites with it.
the newer triband you can use 2 versions.
mnzs-blen
Oct 28, 2022Aspirant
It’s easy mesh compatible router. Hence any extenders that has compatibility of Easy Mesh can be added !
https://kb.netgear.com/000061555/What-is-EasyMesh-and-how-does-it-work-with-my-NETGEAR-Mesh-WiFi-6-System
