MSBassSinger
Jan 26, 2023Aspirant
MR60 Denial of Service Attacks
The past few weeks, I have been getting a lot of DOS attacks, some bad enough that the MR60 goes offline for a minute or so, then returns. I have a Netgear GS108v4 switch wired into the MR60 etherne...
microchip8
Jan 26, 2023Master
False positives.
NETGEAR's firmware is known for creating many false positives. This puts a strain on the CPU. As you can see in your log, there are even "attacks" from your local deices (192.168.x.x IP addresses).
I'd disable DoS protection completely and see if the issues goes away. You're not missing much since most are, as I mentioned, false positives.
MSBassSinger
The MR60 has no DoS protection, at least nothing tha is settable via the web or app interface.
