MSBassSinger
Jan 26, 2023Aspirant
MR60 Denial of Service Attacks
The past few weeks, I have been getting a lot of DOS attacks, some bad enough that the MR60 goes offline for a minute or so, then returns. I have a Netgear GS108v4 switch wired into the MR60 etherne...
microchip8
Jan 26, 2023Master
False positives.
NETGEAR's firmware is known for creating many false positives. This puts a strain on the CPU. As you can see in your log, there are even "attacks" from your local deices (192.168.x.x IP addresses).
I'd disable DoS protection completely and see if the issues goes away. You're not missing much since most are, as I mentioned, false positives.
MSBassSinger
I can understand false positives. Why would the router go offline (amber light) then come back online? Is that preventable?
- FURRYe38Jan 26, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Whats the user manual say for LED behaviors on the MR?
