MSBassSinger
Jan 26, 2023Aspirant
MR60 Denial of Service Attacks
The past few weeks, I have been getting a lot of DOS attacks, some bad enough that the MR60 goes offline for a minute or so, then returns. I have a Netgear GS108v4 switch wired into the MR60 etherne...
MSBassSinger
The IP is registered to Comcast, my ISP. 🙂
Jan 26, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What's the user manual say for LED behaviors on the MR?
