posttrad
Oct 13, 2022Tutor
MR60 dhcp errors
Been having a lot of trouble with this router going offline and only being able to come back after a reset. some devices will reconnect but most give dhcp errors. I sometimes have to reset the router ...
Oct 13, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- posttradOct 13, 2022TutorFactory reset firmware
Spectrum modem not sure of the model #
Using Lan cable that came in the box
Sometimes turning Qos on will help for a few days. Not sure if that matters. Also when connected to a MacBook I can only access a few websites while others say server not responding- FURRYe38Oct 13, 2022Guru - Experienced User
What Firmware version is currently loaded on the MK system?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Can you look at the front or back for any printing or sticker information?- posttradOct 13, 2022TutorModem is EN2251 hitron
I can’t currently connect to the admin page to check firmware. Currently restarting/ resetting until I can get a connection on at least one device.
