posttrad
Oct 13, 2022Tutor
MR60 dhcp errors
Been having a lot of trouble with this router going offline and only being able to come back after a reset. some devices will reconnect but most give dhcp errors. I sometimes have to reset the router ...
Oct 13, 2022Guru - Experienced User
What Firmware version is currently loaded on the MK system?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Can you look at the front or back for any printing or sticker information?
posttrad
Oct 13, 2022Tutor
Modem is EN2251 hitron
I can’t currently connect to the admin page to check firmware. Currently restarting/ resetting until I can get a connection on at least one device.
- FURRYe38Oct 13, 2022Guru - Experienced User
Can you disconnnect the MR from the modem and connect 1 wired PC to the MR and factory reset the MR and walk thru the setup wizard with the PC and web browser at 192.168.1.1?
