posttrad
Oct 13, 2022Tutor
MR60 dhcp errors
Been having a lot of trouble with this router going offline and only being able to come back after a reset. some devices will reconnect but most give dhcp errors. I sometimes have to reset the router ...
posttrad
Oct 13, 2022Tutor
Modem is EN2251 hitron
I can’t currently connect to the admin page to check firmware. Currently restarting/ resetting until I can get a connection on at least one device.
Oct 13, 2022Guru - Experienced User
Can you disconnnect the MR from the modem and connect 1 wired PC to the MR and factory reset the MR and walk thru the setup wizard with the PC and web browser at 192.168.1.1?
