schumaku
Feb 15, 2024Guru - Experienced User
MR60 DHCP IP-MAC Address Reservation
MR60 Firmware Version 1.1.7.134_2.0.65
Appears the Address Reservation "feature" is at least partially broken.
When going to the LAN Setup, the Address Reservation table is supposed to be...
Feb 16, 2024Guru - Experienced User
Ok, MS Edge was on Windows 11 Edge Version 121.0.2277.112. I just saw it updated to v.128. I'll check my MRs again after work.
- schumakuFeb 16, 2024Guru - Experienced User
Hard to imagine it's just about the very latest Edge only -:I see the problem since having deployed the MK63S list here to my playground initially, could be caused by the few IP-MAC reservation I have in place, too.
DHCP Address range is 192.168.50.2 ... .254 and the table of the (working reservations) is in your PM inbox soon.
I've expected to operate it on a dedicated VLAN in my lab, but found it does fail miserably on the LAN and it does bring down even more.... Oh well, consumer stuff 8-/- schumakuFeb 16, 2024Guru - Experienced User
New "behavior":
[Add] shows the table,
[Edit] does error out and return to an empty list.
Originally, I had reservations for two more addresses on the list: Two of the satellites, which I had renamed to MS60-1 and MS60-2 in the meantime.
The plot thickens ... several days ag, we had enabled Access Control and added one client to access.
...and the router does report some crazy DoS attack: Fraggle Attack ... and does also (crash) and restart without user intervention:
