schumaku
Feb 15, 2024Guru - Experienced User
MR60 DHCP IP-MAC Address Reservation
MR60 Firmware Version 1.1.7.134_2.0.65
Appears the Address Reservation "feature" is at least partially broken.
When going to the LAN Setup, the Address Reservation table is supposed to be...
schumaku
Feb 16, 2024Guru - Experienced User
Hard to imagine it's just about the very latest Edge only -:I see the problem since having deployed the MK63S list here to my playground initially, could be caused by the few IP-MAC reservation I have in place, too.
DHCP Address range is 192.168.50.2 ... .254 and the table of the (working reservations) is in your PM inbox soon.
I've expected to operate it on a dedicated VLAN in my lab, but found it does fail miserably on the LAN and it does bring down even more.... Oh well, consumer stuff 8-/
schumaku
New "behavior":
[Add] shows the table,
[Edit] does error out and return to an empty list.
Originally, I had reservations for two more addresses on the list: Two of the satellites, which I had renamed to MS60-1 and MS60-2 in the meantime.
- schumakuFeb 16, 2024Guru - Experienced User
The plot thickens ... several days ag, we had enabled Access Control and added one client to access.
...and the router does report some crazy DoS attack: Fraggle Attack ... and does also (crash) and restart without user intervention:
....and after editing the name of one device in the Access Control (a MS60 satellite) ...
...it magically shows up in the LAN List, too
Bugware - back to the sender for FIXES!!!!
- FURRYe38Feb 16, 2024Guru - Experienced User
What was the custom name of the MS in Access Controls. I'll see if I can reproduce this on mine.
I usually leave the MS names defaults with slight change to the end of the name, i.e. -DR or -BM. Though I don't normally use Access Controls so I'll check on this as well.
Give me some steps to set this up so I can test this out.
If you can reproduce this all the time, enable debug logging on the MR and reproduce, then save off the debug logs. We can get them to NG.
