dbshane
Nov 24, 2022Tutor
mr60 dhcp not working
Same issue here. Default SSID works fine after resetting, but after changing SSID, DHCP doesn't work. Older firmware does seem to work (1.0.6.102), but I had to update the firmware to finish up the s...
Nov 27, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to factory reset the MR and setup from scratch.
I recommend changing the DHCP pool size to .100 thru .200 as well.
I've not seen this on my MK63 system with v.132 loaded....I change SSIDs some what frequently.
- dbshaneNov 30, 2022Tutor
Thanks. It's not the cable. I downgraded to 1.0.6.102 and reset the router without internet cable. Now everything works.
- FURRYe38Nov 30, 2022Guru - Experienced User
Next time, factory reset the system and setup from scratch after updating FW.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
