demarlio25
Oct 06, 2023Aspirant
MR60 Disconnecting
Hello, For some amount of time I've been having issues with my computing disconnecting from remote sessions though VNCSERVER or SSH. I had thought that maybe it was my VPN causing the issues but...
demarlio25
Oct 10, 2023Aspirant
Thanks for the response! By the way, this happening to multiple PCs (windows and Linux)
| Firmware Version | V1.1.7.134_2.0.65 |
Hitron Technologies EN2251 - I just got this a few months ago but was also happening with the previous modem.
I am using a CAT 5e cable. I will try some other cables that I have.
I have 4 MS installed. They are scattered throughout the house. The closest is probably 30 feet away and the farthest might be 60 feet away from the MR.
The IPs have NetName of GOOGLE, MSFT, GOOGLE-CLOUD, AT-88-Z (Amazon is the organization).
Devices are wireless to the MR/MS, but I've previously had them wired to the MS.
Oct 10, 2023Guru - Experienced User
Definitely try CAT6 cabling.
- demarlio25Oct 10, 2023Aspirant
The house is 3 story, about 3800 sq ft.
I ordered a CAT6 and will try that when it comes in.
No resets have been performed, will try that if the CAT6 doesn't fix the problem.
- FURRYe38Oct 10, 2023Guru - Experienced User
Might also try reducing the MS deployment by one or two.
- demarlio25Oct 11, 2023Aspirant
I did a factory reset and when setting up my satellites it only found 2 out 4. I am going to run with the 2 and see how stable the connection is, maybe the 2 satellites were on the edge of the range and were causing the connection issues.
I also changed to a CAT6 cable.
