demarlio25
Oct 06, 2023Aspirant
MR60 Disconnecting
Hello, For some amount of time I've been having issues with my computing disconnecting from remote sessions though VNCSERVER or SSH. I had thought that maybe it was my VPN causing the issues but...
michaelkenward
Oct 10, 2023Guru - Experienced User
demarlio25 wrote:
I dug a little further and started looking at the logs from my MR60 and was seeing that often the disconnects would be associated with DoS attack notifications in the log.
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
- demarlio25Oct 10, 2023Aspirant
Thanks for the tips. I will try to remove the logging and see if that helps.
