youngjaekim
Nov 22, 2022Aspirant
MR60 does not allow to connect Wifi Speaker, but MS60 allows.
Hi. I have 2 wifi speakers and all of them can be synced and played via Chromecast + YouTube Music. It's cool. But, one thing I've found really weired issue. It does not connected when both ...
youngjaekim
Nov 24, 2022Aspirant
Hi.
1. Firmware
I've upgraded firmware 1.1.6.122 to latest 1.1.7.132 and it's still not working.
2. Shutdown MSs
Same. The phone cannot reach to Speakers
3. Airplay also not working
I found iPhone XS AirPlay also shows same symptom; not working in MR, but works well as the image depics.
I think MR blocks device-to-device communication. hmm. I couldn't found but is there any configuration related to allow/block between connected devices in MR station? I'm not using Access Control nor DMZ.
Nov 24, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed yet? Don't load any saved backup from file.
Being that the MR would be the only one online with your devices, it should not be blocking anything. Odd that this is working with the MS but not the MR...
