uhcax30
Mar 22, 2023Aspirant
MR60 Drops wifi but wired works
Hi I have a MR60 with 2 satellites connected to CAX30 I am using CAX30 as modem, hence there is no ISP modem. ISP is Xfinity On a regular basis ( at least once a day) I notice that my MR60 dr...
Mar 22, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
Try setting manual channel 1 on 2.4Ghz and 40 channel on 5Ghz.
uhcax30 wrote:
Hi
On a regular basis ( at least once a day) I notice that my MR60 drops wifi. All devices hard wired to MR60 continue to work. MR60 drops both 5G and 2.4G wifi connections. Generally in about 15 minutes or so it would restore the connection by itself.
I do not see any errors reported in Log. I do see log lines with [DoS attack: Fraggle Attack] or [DoS attack: RST Scan] on a regular basis. Not sure if this is the cause
I have also seen log line with [WLAN access rejected: incorrect security] from MAC. However the very next line I see a DHCP Ip assigned message for the same MAC.
MR60 is running V1.1.7.134_2.0.65.
5GHz Channel is set to 161 and 2.4GHz Channel is set to auto ( i see it on channel 2).
I had done a full hardware reset couple of months back.
I had seen the issue before I upgraded to the latest version
uhcax30
Home is about 2540 sq.ft. The MR and MS are about 30 feet apart.
All neighbors around have wifi. I do not see anyone using the channels I have setup. However I can try switching the channels.
If one channel has congestion, I would expect the other to continue working. Why would both the 2.4Ghz and 5 Ghz go down at the same time?
- FURRYe38Mar 22, 2023Guru - Experienced User
Which channel has congestion on it? Try 6 or 11. 1, 6 or 11 are primary channels to use on 2.4Ghz, others are sub channels used by the system. 5Ghz can use any.
Also lets try using just 1 MS. Not two...That size of home, maybe only one MS is needed...something to try as a quick test.
