Yakker
May 31, 2023Aspirant
MR60 Ethernet interface less than 100mbps
I have 500mbps service from Spectrum and the "Internet" interface of my MR60 shows 580Mbps down but the "Ethernet" interface only outputs 89Mbps. I have changed out the cables 5 times. I have tried C...
- Jun 01, 2023
I am going to have to resort to my last ditch effort of getting a separate router that can actually negotiate proper ethernet speeds and ditch the MR60 that apparent doesn't know what to do with that information. Thanks for all the assistance ya'll have been great!
michaelkenward
Jun 01, 2023Guru - Experienced User
What's the modem/gateway/ONT between the router and the Internet?
In the browser graphical user interface (GUI), what do you see in the Status column when you Show Statistics?
- Advanced Home
- Show Statistics
Where is this "unmanaged switch" in the network?
- YakkerJun 01, 2023Aspirant
Well Ill be damned... The Show Statistics does indeed show LAN1 interface as having only 100MB, that sucks because I bought this last year not in 2001, I guess I'll need a different router do you have any recommendations?
As for the other questions the Modem is a EU2251 with a 2.5gbps interface > MR60 > Generic 2.5gbps switch > PC- michaelkenwardJun 01, 2023Guru - Experienced User
No, you need to work out why it is doing that. Then fix it.
There is no reason why the MR60 shouldn't work at 1000 Mbps.
What does the Internet Setup look like?
WAN Preference?
This is new territory to me, I have no hope of getting speeds that high. So I am not familiar with things like that.
There are people here who are more familiar with that stuff. I just know a bit abut where to look for clues. Maybe you need to do something to match the 2.5 Gbps interface on the EU2251.
- FURRYe38Jun 01, 2023Guru - Experienced User
What speed do you see if you connect your PC directly to the back of the MR?
What is the brand and model# of the ethernet adapter in the PC?Try a different wired PC connected to the MR.
Does the WAN interface show 1000Mpbs or 100Mpbs on the WAN port on the MR? Should show 1000Mpbs for it's max connection rate.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.FYI, the MR60 will be a bottleneck for your 2.5Gb connection between the Modem and Switch. The MR doesn't support any higher speeds past 1000Mpbs. Might consider getting a router that does support this and maybe configuring the MK60 system into AP mode for continued wireless service.
As for the other questions the Modem is a EU2251 with a 2.5gbps interface > MR60 > Generic 2.5gbps switch > PC- YakkerJun 01, 2023Aspirant
Still the same 100mbps rate as if it was plugged into switch > PC
A generic cheap 2.5gbps PCIE NIC from China,https://www.amazon.com/gp/product/B08V1HG47H/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
The WAN connection is 1000mbps
V1.1.7.134_2.0.65
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.I have loads of different cables, but brand new CAT6 on the way
All settings are default as I have reset to factory settings. The only things that have changed in my network are the switch and NIC of my PC. Is there a chance that the 2.5gbps speed confuses the Nighthawk into running 100base-t?!
I understand this bottleneck; the 2.5gbps NIC and Switch were a "futureproofing" upgrade to an onboard NIC and Netgear switch that failed in a power outage about a week ago. I may as well just spend the dollarydoos and get a 2.5gbps router with a bit of memory and run pihole on it for funsies anyway...
https://www.amazon.com/gp/product/B0BNPTW2L2/ref=ox_sc_act_title_1?smid=A3FZJTJP2FUJVA&psc=1
