LogicaLv
Feb 08, 2023Tutor
MR60 Firmware V1.1.7.134 - Possible issues with this firmware version and DoS/Port Scan Protection
Product Affected: Netgear Nighthawk MR60 Firmware Version (Router & Satellite): V1.1.7.134 I've recently suffered two brief power outages about a week apart from each other and in both instances...
- Mar 22, 2023Checking the option "Disable Port Scan and DoS Protection" resolved the issue for me, even after subsequent power outages.
Feb 10, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
For any Apple or Android mobile devices, be sure to disable the random mac address features on these devices While at home:
