LogicaLv
Feb 08, 2023Tutor
MR60 Firmware V1.1.7.134 - Possible issues with this firmware version and DoS/Port Scan Protection
Product Affected: Netgear Nighthawk MR60 Firmware Version (Router & Satellite): V1.1.7.134 I've recently suffered two brief power outages about a week apart from each other and in both instances...
- Mar 22, 2023Checking the option "Disable Port Scan and DoS Protection" resolved the issue for me, even after subsequent power outages.
LogicaLv
Mar 22, 2023Tutor
Mar 29, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- BLZ6353Apr 26, 2023Guide
Finally got around to a brief visit at the vacation home with the issues. As luck would have it, all the dropped devices had reconnected with the router and satellites just before I was able to visit. The router and satellites were all working with various devices connected to each unit. However, as per suggestion, I removed 2 of the satellites (just installed WiFi plugs and turned off the power to 2 of the satellites so I can possibly use only while I’m there). When I tried the solution of “Disable Port Scan and DoS Protection” devices immediately began disconnecting from the network. Reverted the setting (unchecked the box) and items reconnected. I will have to wait for time to pass and also after power outage(s) to see if the reduction in the number of satellites resolves the problem of dropped devices
