AtlasEnzo
Oct 12, 2021Aspirant
MR60 flashing white light need to update firmware but will not connect to internet
AtlasEnzo
Oct 13, 2021Aspirant
1. Not sure what the latest firmware was. I know I had an update though. Can’t reconnect it to see either.
2. Viasat 2 in 1 gateway modem. Triangular looking one
3. Viasat
I think I need to unbrick it from what I’m reading.
3. Viasat
Oct 13, 2021Guru - Experienced User
What viasat gateway/modem is it?
Viasat uses main gateway's with their own integrated router.
it can cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- AtlasEnzoOct 15, 2021Aspirant
Viasat Gateway/Modem: Model No. RG1100
So, I tried option (1) and could not connect to Netgear MR60. Flashing white light continuously. I reset everything to wear it was before trying option (1) and then did option (2) whichg had the same results as option (1). Continuous flashing white light. So, I reset everything again and I'm back to where I started. Didn't want to do option (3) and did not try. I wasn't too keen on losing all the features listed.
