uhcax30's avatar
uhcax30
MR60 Guest Network isolation
I have MR60 and two satellites connected to a CAX30. The MR60 acts as a Router.  I am not able to isolate Guest network from internal network. I do not see any option to block guest network from seei...
  • FURRYe38's avatar
    I'll see if I can find out if this is expected behavior. As long as you can't access those device, should ok.
