uhcax30
Sep 20, 2022Aspirant
MR60 Guest Network isolation
I have MR60 and two satellites connected to a CAX30. The MR60 acts as a Router. I am not able to isolate Guest network from internal network. I do not see any option to block guest network from seei...
- Sep 21, 2022
I'll see if I can find out if this is expected behavior. As long as you can't access those device, should ok.
uhcax30
I am able to scan the network and see every device on the network.
I am running the latest version of firmware on both MR60 and MS60s.
Sep 20, 2022Guru - Experienced User
Can you access any of the devices from the guest side?
I saw my Wired Windows 10 PC on my Mac Book that was connected on the GN. However I could not access it's shared folders. When i changed the Mac Book to the main wifi network, I could then access the shared folders.
- uhcax30Sep 21, 2022Aspirant
Yes you are right. I was not able to access any services. However I was able to scan the network and view which all devices existed
- FURRYe38Sep 21, 2022Guru - Experienced User
