uhcax30
Sep 20, 2022Aspirant
MR60 Guest Network isolation
I have MR60 and two satellites connected to a CAX30. The MR60 acts as a Router. I am not able to isolate Guest network from internal network. I do not see any option to block guest network from seei...
- Sep 21, 2022
I'll see if I can find out if this is expected behavior. As long as you can't access those device, should ok.
uhcax30
Sep 21, 2022Aspirant
Yes you are right. I was not able to access any services. However I was able to scan the network and view which all devices existed
Sep 21, 2022Guru - Experienced User
