Texaswiseguy
Apr 08, 2025Follower
MR60 Help
I need help. If the MR 60 is even worth saving. I have had this since 2020. And enjoyed maybe one year of connectivity. Quite certain the firmware is well out of date. It will not connect to my netwo...
michaelkenward
Apr 09, 2025Guru - Experienced User
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
It will not connect to my network. Therefore, it is not extending sad network.
What will not connect to your network? The MR60?
What else is on the network for it to connect to?
Disclaimer: Just another user with time on their hands.
