MrMusAddict
Dec 08, 2021Aspirant
MR60 How to block devices based on a schedule?
I seem to be able to block/allow devices wholly/completely. I also seem to be able to set a global schedule. But I do not appear to be able to schedule access per device. Is there a way to do so? ...
Dec 08, 2021Guru - Experienced User
Might see if this is seen on your MR:
If not, this model may not support this feature...
- MrMusAddictDec 08, 2021Aspirant
FURRYe38 Is there a list of devices I can refer to that support this as a feature?
- FURRYe38Dec 08, 2021Guru - Experienced User
Select the links in that article under "This article applies to:"
