santeeslim
May 05, 2022Tutor
MR60 intermittent failures
I've been having intermittent failures with my new router as show in the following log file. Is this normal? If not, what can I do to correct it.? Wait for Ping (milliseconds): 200 Test Interval (s...
May 05, 2022Guru - Experienced User
1. what firmware are you on?
2. what modem/gateway is it connected to?
3. how often is it happening?
4. does it happen to just wired devices or do wired drop as well?
5. what fixes the issue?
- santeeslimMay 05, 2022Tutor
1. I have the current firmware, updated when the product was installed about two weeks ago. The modem firmware is V1.01.14
2. It's connected to the Netgear DOCSIS 3.0 16 DS 4 US modem
3. It occurs as often as shown in the log file I sent
4. I don't have any wired devices.
5. It recovers by itself.
In addition to this question, I get what appears to be halts for buffering near the beginning of most programs. I say "appears to be buffering because I have no way to know it that's actually what it is.
The firmware in my router is Version V1.1.6.124_2.0.59
Sorry for the earlier lack of info.
- plemansMay 06, 2022Guru - Experienced User
so the goal is to figure out where exactly the issue is coming from.
If you have no wired devices and your getting a lan fail notice, the only thing connected with ethernet is the modem.
so is the error coming from the modem or the router side.
Do you have a screen snip of the modems cable connection page and event logs?
have you replaced the cable between modem/router?
- santeeslimMay 06, 2022Tutor
I think this is what you want, and no, I haven't replaced any cables. CORRECTIOIN: I have my deskto PC connected to the router with an ethernet cable.
