santeeslim
May 05, 2022Tutor
MR60 intermittent failures
I've been having intermittent failures with my new router as show in the following log file. Is this normal? If not, what can I do to correct it.? Wait for Ping (milliseconds): 200 Test Interval (s...
May 05, 2022Guru - Experienced User
1. what firmware are you on?
2. what modem/gateway is it connected to?
3. how often is it happening?
4. does it happen to just wired devices or do wired drop as well?
5. what fixes the issue?
santeeslim
May 05, 2022Tutor
1. I have the current firmware, updated when the product was installed about two weeks ago. The modem firmware is V1.01.14
2. It's connected to the Netgear DOCSIS 3.0 16 DS 4 US modem
3. It occurs as often as shown in the log file I sent
4. I don't have any wired devices.
5. It recovers by itself.
In addition to this question, I get what appears to be halts for buffering near the beginning of most programs. I say "appears to be buffering because I have no way to know it that's actually what it is.
