santeeslim
May 05, 2022Tutor
MR60 intermittent failures
I've been having intermittent failures with my new router as show in the following log file. Is this normal? If not, what can I do to correct it.? Wait for Ping (milliseconds): 200 Test Interval (s...
santeeslim
May 08, 2022Tutor
Thanks very much for your help. I moved the modem and router to the point at which the Internet cable enters the house, I now have zero errors on either log.
Thanks again.
May 09, 2022Guru - Experienced User
glad that cleared it up!
If it stays clear, you might mark it as solved so others aren't trying to "fix' the issue as well as others might see what you did to resolve it.
