SK_AKU
Dec 14, 2022Aspirant
MR60 is good but MS60 very poor speed
I connected my Spectrum Modem to MR60 (router) in the basement where I get 350MBPS and from router I connected to Netgear GS308v3 and from that I have Ethernet ports connected to TV's and a desktop w...
Dec 15, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Might revert back to v.124 on the MS first then MR lastly to see if this changes anything...
SK_AKU
Dec 15, 2022Aspirant
Q. What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
A. ISP's modem manufactures model# ET2251
Q. Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
A. LAN cables are new and I get 350MBPS+ from the router (MR60) which is good. I have issue only with MS60's without any speed
The purpose of Mesh network supposed to cover full house but I get speed only near the router but not near the satellite from past 3 to 4 weeks
- FURRYe38Dec 15, 2022Guru - Experienced User
Let us know if the other suggestions help any...
