lberezinski
Feb 22, 2024Aspirant
MR60 is it possible to restrict a target access to only one source on the network?
I have an MR60 mesh system and Im looking to restrict access of a device on my network to only one source IP. Is that possible?
Feb 22, 2024Guru - Experienced User
Are you trying to setup a reserved IP address?
Like michaelkenward says, your description leaves a lot to be desired
- lberezinskiFeb 22, 2024AspirantI want to restrict access to a camera on the network so that only my NVR, which is also on the same network, can access it. All other network devices should be denied access.
- FURRYe38Feb 22, 2024Guru - Experienced User
Something to ask the mfr of this camera and NVR system about. Anything connected on the same network would have access to these devices, unless there is passwords set up on these devices, if they support that. Something to ask the Mfr about.
- michaelkenwardFeb 22, 2024Guru - Experienced User
lberezinski wrote:
I want to restrict access to a camera on the network so that only my NVR, which is also on the same network, can access it. All other network devices should be denied access.Why?
If you have instal devices that demand internet access, disabling that connection will disable the devices. Is that what you want?
