Phillips60
Mar 23, 2024Aspirant
MR60 Lag Spikes
I have a Nighthawk MR60 Mesh system, and for the past couple of months now I have been getting lag spikes that appear for around 5 seconds and then go away. It happens constantly on different compute...
michaelkenward
Mar 23, 2024Guru - Experienced User
In the absence of any useful information, the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
