Phillips60
Mar 23, 2024Aspirant
MR60 Lag Spikes
I have a Nighthawk MR60 Mesh system, and for the past couple of months now I have been getting lag spikes that appear for around 5 seconds and then go away. It happens constantly on different compute...
michaelkenward
Mar 24, 2024Guru - Experienced User
Phillips60 wrote:
[DoS attack: Fraggle Attack] from source UNKNOWN,port 443 Sunday, Mar 24,2024 14:32:30
[DoS attack: Fraggle Attack] from source UNKNOWN,port 443 Sunday, Mar 24,2024 14:28:20
But searching it up seems to indicate that it’s a red herring.
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
If these events are slowing down your router, that may be because it is using up processor time as it write the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
Phillips60
Mar 24, 2024Aspirant
Unfortunately that didn’t fix it either. Cleared the log and rebooted it as well, but the problem’s still there. In the ping test.
