DuckTM
Feb 05, 2024Aspirant
MR60 Mesh + Satellites - Ethernet devices making unecessary hop through satellite
My network setup consists of the MR60 router (firmware V1.1.7.134), two satellites, and two 8-port unmanaged/dummy switches. One satellite is connected while the rest of the network is connected thr...
- Feb 06, 2024Powered everything on in order and no joy. After taking another look at the switch, no matter what port the router is connected to the port doesn’t light up green. Is the Ethernet port on the router somehow damaged?
Edit: Yes, I’ve tried multiple cables
Edit2: Yes, it’s the router port. It’s not even 6 months old so who knows if it’s been that way since I got the router.
DuckTM
Feb 06, 2024Aspirant
> What's the brand and model# of these non managed switches you have in use?
Netgear GS108E is Switch 1(connected directly to router) and Netgear GS108 is Switch 2(connected to switch 1)
> What is the CAT# LAN cable being used?
Cat5e - Self-terminated, all ends double-checked as of last night.
Feb 06, 2024Guru - Experienced User
What happens if you remove the GS108E switch from the mix. This is a semi managed switch and they have been known to cause odd problems. Why non managed switches are recommended for use if connecting satellites to the router for wired backhaul support. The GS108 is a non managed switch.
- DuckTMFeb 06, 2024Aspirant
> What happens if you remove the GS108E switch from the mix. This is a managed router and they have been known to cause odd problems.
Well, that could explain some things. I'll try that out when I get home in the next 30 minutes. I'm currently in school. Thanks for the info!
- FURRYe38Feb 06, 2024Guru - Experienced User
- DuckTMFeb 06, 2024AspirantI replaced the GS108E with the GS108. My computer (tied to SW2, now in place of SW1) shows that it is connected but cannot access the internet or router http interface. The app shows that they were last connected to Sat2 but currently have no connection.
