NathanVos
Oct 03, 2024Aspirant
MR60 Mesh and AP mode
I've been using the MR60 and two satellites for a while, and I had them connected to my Nighthawk R7000 without any issues. After upgrading my internet, I noticed that the R7000's LAN speeds weren't ...
- Oct 21, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 03, 2024Guru - Experienced User
Yes, the MS should work with the MR while in AP mode.
Did you have the MR in AP mode while connected to the R7000?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Recommended process for AP mode:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
- NathanVosOct 03, 2024Aspirant
I should also note that the main MR60 is plugged into the host router, and the satelites are connecting wirelesses via the mesh to the MR60.
That I do now know. I dont think so. However the R7000 also defaults to ip range 10.0.0.1/255 when there is a provider with the 192.0 range as well so maybe that is why it worked. I would have thought that it would have duplicate ips though from 2 different dhcp servers 1 on the MR and 1 on the R7000.
-------------------------------------------------------------Firmware v1.1.7.134
The service is next gen fiber, and the model is Nokia XS-2426X-A
Cables are CAT6
Think I should set the MR60 as AP before or after I sync the Satelites >? Would it make a difference?
- FURRYe38Oct 03, 2024Guru - Experienced User
I would configured the MR and MS in router mode first. To be sure the MS are connected to the MR while in router mode.
What is the IP address pool string from the Nokia router? 192.168.1.1 or .0.1?
What is the default IP address pool range of the Nokia router? .2. to .254?
Is the WiFi radios on the Nokia router disabled and turned OFF?
- NathanVosOct 03, 2024AspirantRe: MR60 Mesh and AP mode
It is 192.168.1.1
Yes
Yes turned off
