NathanVos
Oct 03, 2024Aspirant
MR60 Mesh and AP mode
I've been using the MR60 and two satellites for a while, and I had them connected to my Nighthawk R7000 without any issues. After upgrading my internet, I noticed that the R7000's LAN speeds weren't ...
- Oct 21, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 03, 2024Guru - Experienced User
Yes, the MS should work with the MR while in AP mode.
Did you have the MR in AP mode while connected to the R7000?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Recommended process for AP mode:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
NathanVos
I should also note that the main MR60 is plugged into the host router, and the satelites are connecting wirelesses via the mesh to the MR60.
That I do now know. I dont think so. However the R7000 also defaults to ip range 10.0.0.1/255 when there is a provider with the 192.0 range as well so maybe that is why it worked. I would have thought that it would have duplicate ips though from 2 different dhcp servers 1 on the MR and 1 on the R7000.
Firmware v1.1.7.134
The service is next gen fiber, and the model is Nokia XS-2426X-A
Cables are CAT6
Think I should set the MR60 as AP before or after I sync the Satelites >? Would it make a difference?
- FURRYe38Oct 03, 2024Guru - Experienced User
I would configured the MR and MS in router mode first. To be sure the MS are connected to the MR while in router mode.
What is the IP address pool string from the Nokia router? 192.168.1.1 or .0.1?
What is the default IP address pool range of the Nokia router? .2. to .254?
Is the WiFi radios on the Nokia router disabled and turned OFF?
- NathanVosOct 03, 2024AspirantRe: MR60 Mesh and AP mode
It is 192.168.1.1
Yes
Yes turned off
Ok, what I would do first is set the Nokia router Default DHCP IP address range to 192.168.1.100 to .200.
Then setup the MR and MS after they are fully connected with the MR in router mode, configure AP mode. Configure a static IP address setup on the MR for AP Mode as linked in previous post in a PDF file.
Configure the MR static IP address of 192.168.1.60. This will be outside of the Nokias new default DHCP IP address pool and is fine. Subnet mask to be same as Nokias, should be 255.255.255.0 and the gateway should be 192.168.1.1 which is the Nokias IP address. DNS you can use same 192.168.1.1 or use custome DNS for the MR in AP Mode. I like to use quad9. When you get the setting configured on the MR for AP mode, apply the setting and then you can connec the MR to the Nokia router using the WAN port on the MR to the LAN port on the Nokia router. As the MR reboots give it a minute or two and should see BLUE front LED. MS should reboot as well and get a IP address automatically thru the MR from the Nokia router. Give it a few minutes. I'd have the MS near or in same room with the MR while you do this configuration. Follow the PDF file I linked for recommended AP mode configuration.
