NathanVos
Oct 03, 2024Aspirant
MR60 Mesh and AP mode
I've been using the MR60 and two satellites for a while, and I had them connected to my Nighthawk R7000 without any issues. After upgrading my internet, I noticed that the R7000's LAN speeds weren't ...
- Oct 21, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
NathanVos
Update - I disabled armor, and made sure the devices where far apart so they didnt try to talk to themselves instead of the MR60. Works. Thanks for the advice 🙂
Oct 21, 2024Guru - Experienced User
Enjoy. 📡
