Dano22
Jan 07, 2021Follower
MR60 Mesh and Chromecast
I am wondering if there is going to be a fix for the NETGEAR - Nighthawk AX1800 Dual-Band Mesh Wi-Fi 6 System (2-Pack) with chromecast compatibilty. From all the forums that I see there is no actualy...
Christian_R
Jan 14, 2021NETGEAR Employee Retired
Hello Dan,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
janieflames
Apr 30, 2021Aspirant
Same issue. I spent 1 hour on the phone with Netgear support. We changed the channels and reinstalled the Chromecast, trying to test it out. By the end of the call, it seemed to work. Later that day, back to same problem. I spent $30 on long distance for the call BC I'm in Canada and the call was to California. I also want to return my product. Very frustrating.
- janieflamesApr 30, 2021AspirantI can tell you, too, that I have two Chromecasts. The one on the same floor as the router works fine. The one on the upper floor sits within 2 feet of the satellite (both located behind the TV) and doesn't work.
- BrissieGoonerMay 01, 2021Initiate
I have a similar problem. I find that the Chromecast located near the MS60 satellite when connected to the 5ghz band won't cast. When connected to the 2.4 ghz band it casts without problem.
A quick solution would be to manually connect the Chromecast to the 2.4 ghz band but according to Netgear support the Nighthawk automatically connects the devices to the 2.4 and 5 ghz bands.
This is something Netgear need to address.
