MPJr's avatar
MPJr
Initiate
Jun 29, 2022
MR60 mesh router connected to CM1000 cable modem: "No internet connection"
I was able to successfully install my MR60 (AX3000) Nighthawk mesh router (with two satellites) to my CM1000 Nighthawk cable modem about a month ago. Router and satellites were providing Wi-Fi to eve...
  • plemans's avatar
    Jun 29, 2022
    Try this.
    power off both the modem and the router and disconnect everything from both. Even coax from the cm1000.
    Wait 1 minutes.
    Then connect coax back to the modem and power it on.
    Wait 2 minutes.
    Then connect it back to the wan port on the MR60 and power the mr60 on.
    Give it a few minutes and then try it.
