MPJr
Jun 29, 2022Initiate
MR60 mesh router connected to CM1000 cable modem: "No internet connection"
I was able to successfully install my MR60 (AX3000) Nighthawk mesh router (with two satellites) to my CM1000 Nighthawk cable modem about a month ago. Router and satellites were providing Wi-Fi to eve...
- Jun 29, 2022
Try this.
power off both the modem and the router and disconnect everything from both. Even coax from the cm1000.
Wait 1 minutes.
Then connect coax back to the modem and power it on.
Wait 2 minutes.
Then connect it back to the wan port on the MR60 and power the mr60 on.
Give it a few minutes and then try it.
Jun 29, 2022Guru - Experienced User
Try this.
Wait 1 minutes.
Wait 2 minutes.
MPJr
Plemans, thank you so much. It worked. Once again, I have a blue light and I have internet connection out of the router. Now, I will try reconnecting the satellites.
