scoobasteve
Nov 02, 2021Tutor
MR60 Mesh WiFi 6 Router can't perform factory reset
I can't perform a factory reset on my MR60 router. The LED is blinking white from the moment I power it up. I even performed a 30/30/30 and it won't reset. Any suggestions?
- Nov 02, 2021
I just contacted Netgear support. After troubleshooting, they informed the firmware was corrupted. I will be returning it for a new one. Thank you for your help.
scoobasteve
Nov 02, 2021Tutor
Nov 04, 2021Guru - Experienced User
good luck with the next unit
