JoeFromSD
May 28, 2024Aspirant
MR60 Mesh Wifi, Red Light
OK Folks, the Mesh WiFi 6 Router has a solid red light, but shouldn't it be green? I have wifi / internet access on the desktop so it is working. Am I good? If not what do I do now? I unplugged it t...
May 28, 2024Guru - Experienced User
Should be BLUE for good status and connection to ISP modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
JoeFromSD
Darn I suspected I'd be asked techy things that I can't answer ..
Firmware, how do I find the version? It's never been updated, at least not by me. How do I update this?
yes I've unplugged both the modem and the modem twice.
