jgg1950
Mar 06, 2022Apprentice
MR60 MS60 Windows 11
Hello, Are they supported in Windows 11 system?
- Great thanks
Are what supported?
the routers don't care what operating system your'e running.
They just broadcast wifi. Its on the operating system to have the wifi drivers/software.
(but yes, windows 11 will connect to netgear routers if you've installed the proper drivers for your wireless card)
- jgg1950ApprenticeGreat thanks
