jasonyang
Mar 04, 2022Aspirant
MR60 must connect to another router to work
I am having a problem with MR60 connect to the internet. When I setup the router directly connect to modem, there is no internet connection. But if I connect MR60 to another router and connect that r...
- Mar 07, 2022
It didn't work, but I finally fixed the issue by downgrading the firmware to V1.0.6.116 and factory reset the router. I also manually change the MAC address to another router.
jasonyang
1. what modem are you connecting it to?
Motorola MB7621
2. what firmware is on the router?
V1.1.6.122_2.0.58
3. what router are you connecting it to to make it work?
Netgear R6700
Mar 04, 2022Guru - Experienced User
Try this.
Power off the modem and the router and disconnect everything from both.
Even the coax from the modem.
Wait up to 10 minutes. (at least 2)
Then connect the coax back to the modem.
Power the modem on and wait 2 minutes.
Connect the lan cable from modem to wan port on the router.
Power the router on.
Wait 2 minutes.
Attempt to go into the router and setup internet.
Reason I say wait up to 10 minutes is sometimes it takes a bit for the ISP to reassign the ip address that was assigned to the R6700.
- jasonyangMar 07, 2022Aspirant
- plemansMar 07, 2022Guru - Experienced User
If that fixed it, you can mark it solved so others aren't trying to fix it as well.
Plus it might help others with the same issue.
glad you hear you got it working
- ScDoMar 08, 2022Initiate
Just wanted to say thank you for this post and thread. Helped me get my mesh system working again after one of the satellites when to amber light.
