jasonyang
Mar 04, 2022Aspirant
MR60 must connect to another router to work
I am having a problem with MR60 connect to the internet. When I setup the router directly connect to modem, there is no internet connection. But if I connect MR60 to another router and connect that r...
- Mar 07, 2022
It didn't work, but I finally fixed the issue by downgrading the firmware to V1.0.6.116 and factory reset the router. I also manually change the MAC address to another router.
jasonyang
Mar 07, 2022Aspirant
Mar 07, 2022Guru - Experienced User
If that fixed it, you can mark it solved so others aren't trying to fix it as well.
Plus it might help others with the same issue.
glad you hear you got it working
- ScDoMar 09, 2022Initiate
Just wanted to say thank you for this post and thread. Helped me get my mesh system working again after one of the satellites when to amber light.
