MattQ's avatar
MattQ
MR60 Network problems. IP confliction?
I have tried connecting to my router multiple times through the app but it says it cannot be detected and even through routerlogin.net (and the ip addresses for it), It can't be accessed as it believ...
  • FURRYe38's avatar
    Ok.
    You should be able to access the MRs web page at 192.168.1.1 then on the PC that's connected in back of the MR.
    You might disconnect the MR from the ISP modem temporarily. Then factory reset the MR by pressing the reset button for 10 seconds then give the MR a minute, then try 192.168.1.1 in a web browser. The setup wizard should appear with the Nighthawk app asking you to use it. Scroll down to the very bottom of this page and select the text that says I don't have a mobile device. This will start the web browser setup wizard.
