BV11
Jul 12, 2021Follower
MR60 no cable detected
I bought a mesh system and have just tried to set it up. It's not recognizing it's connected to my Arris CM820 modem. I have tried all manner of restarting. Unfortunately, it took me a while to set it...
Jul 15, 2021Guru - Experienced User
Try this.
power off both the CM820 and the MK system.
disconnect everything from both (even coax) and wait 2 minutes.
then connect coax back to t he cm820 and power it on.
Wait 2 minutes for it to fully boot.
then connect the lan cable from cm820 to the wan port on the MR60.
then power the mr60 on. Give it 2 minutes to fully boot.
then attempt setup.
