jtqbcsm3
Jan 07, 2023Aspirant
MR60 No Internet after SSID Change
I Have a Nighthawk MR60 and 2 satellites. I did an update on the router and lost internet. I then had to reset the router and the internet works on the Default Netgear settings. When i change the SSID back to what it was, i can connect but No Internet. Please help!
What FW was loaded on the MR and MS?
Did you update the MS first then the MR lastly?
Did you manually update the system as seen here?
- jtqbcsm3Aspirant
This is the Firmware Version 1.1.7.134
I did the update on the Nighthawk app. so i do not believe it was the way shown.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.Last resort you should manually download the MS and MR FW files and re-load the MS first and MR lastly using a wired PC and web browser.
