k5blazer
Jul 12, 2022Aspirant
MR60 No Internet from wireless
using MR60 mesh system I am not able to access the internet wirelessly connecting my laptop to the ethernet port I am able to access the router. Says my internet is connected and wireless is turned o...
- Jul 20, 2022
::RESOLVED::
had the C3000Z in radio disable mode.
I was able to see the wireless network from my phone and other devices. when trying to connect I would get could not obtain IP. Nothing was auto connecting at this time. using my laptop and hard wired to the modem MR60 I was able to get online through it, and see the GUI and see all the settings. My security settings were set to WEP2, the reasons of none... I turned off Security and set to OFF. My phone then auto connected so did the Wife's phone. Which was weird, at this point i turned Security back on WEP2 again. (same that I was using) turned WIFI off on my phone and turned back on. The phone auto connected and all of my devices in my home from computers, tvs, phones, and smart devices all connected back to the network.
I guess it was something in the security settings?
Thank you for the help on this subject.
k5blazer
Jul 20, 2022Aspirant
::RESOLVED::
Jul 25, 2022Guru - Experienced User
Enjoy. 📡
